- 05.07.2024, 21:42
#576283
Hello Hello
I fix the truck...it was my foult. I didn't attached Verteiler correctly .
I play with a little and the best/stable idle is at 5 deg.
Interesting is the way Jetronic controls the idle ignition advance . Vacuum line to Verteiler is controlled by solenoid. On 0 throttle solenoid is on and block vacuum to Verteiler, when throttle is applied solenoid shut off and vacuum is applied to Verteiler and respectively advanced ignition.....cool retro solution.
In next MonoJetronic models (golf 3, astra etc)...ignition is fully controlled by ECU (there is no weights and vacuum actuator in Verteiler)....just for the record.
