- 11.04.2024, 19:44
#575056
Hi Andrey
so if I understand correct, you added now a new cable from battery + via a new relay and a new fuse direct to the + of ignition coil. The relay is triggered by a new cable direct from key switch (Klemme15) .
The cable between battery + and starter is still the original 50mm² cable.
So to see how the voltage drop is at the ignition coil you can measure this directly at the coil not on the point you showed above.
What value for the fuse you put in?
Bis dene
Jürgen von der hessischen Kinzig
Truck-Trial und mehr auf unserer TeamPage
Team-FaMoS
Termine
Team-FaMoS
Termine
