- 24.03.2024, 20:23
#574669
Hi...new in forum.
So long story short...I receive message from space that I need 404 Unimog....and after month in research, I'm a happy owner of 1964 fire truck, which in some moment probably was converted to kipper.
The odo shows 28 550 km.
It has front PTO.
Kipper is probably from small truck with electric pump...not finished.
I have the truck from a week. I was more or less prepared that this truck is 60 year old and there should be some work done on some places....but not i such scale.
Have some experience with old vehicles ...but this too retro
I'll need some advices in the process, so fill free to help
SO...what I have done.
Fuel system
It's a complex one...two tank-selsctor -mechanical pump- electric pump. I decide to simplified the system:
- so I leave just one tank,
-make aluminum flange on place of electric pump whit suction, return and vent line
- place a fuel sender on place of old return line
-make a custom bracket with fuel filter and low pressure electric pump
-put a new fuel line
some how works...need more modification
24 to 12V
it's appear that 24V system is pain with the parts...everything is hard to find. I took a decision to switch to 12V system.
For now:
- I throw out the Generator with regulator and starter.
-Put a 12V starter...spins good.
- new + line between starter and some distribution joint
...need to source some old school alternator and to adapt it...and of course to change some bulbs. Blower and wisher will work at half speed...forever ..don\ plan to play with them.
Air system
too complicated...with air brakes for trailer
I cut it complete out.
Brakes
Should solve problem with brake booster, as far as I remove compress air system
Andrey
It has front PTO.
Fuel system
24 to 12V
For now:
Air system
Brakes
Andrey
Zuletzt geändert von Andrey Nikolov am 09.04.2024, 16:18, insgesamt 1-mal geändert.
