#539559
I know, it's a weird question.
I'm 6'2" (1.87m) and 270# (122kg) - it is a tight squeeze to get into my Frogeye! My 404 is comfortable, although I have to hunch down a little to see out of the windshield.
Making the problem worse are my feet: I wear a US size 16, so it is very difficult to get them in and around the pedals and steering column. I am tempted to modify the lower engine/transmssion cover plate to give myself another inch or so on the right side, and maybe modify the left side with a curve, like the 404 has.
It would also be helpful if there was some sort of handle on the upper A-pillar like the 404 has.
#539876
Hello !
I have the same Problems with my great shoes. My shoe`s are 46er Workershoes and i can`t reach the right Pedal normaly. My Idea is to put the Westfalia Cabin 3cm to the right, so my great shoe`s will match into the Slot.
Nice Day from Austria
Mike
Hallo Falk, Raucht der Motor beim Orgeln wei&szli[…]
Bremsprobleme U1200 424
Vielen Dank für die schnelle Antwort, dann we[…]
Hallo Könnte vermutlich ein Überwurf vo[…]
Mautpflicht der Mogs
Guuden, kleine Berichtigungen: Zitat: „Di[…]
