Neues Forum für die Unimog- und Reise-Freunde weltweit.
#42436
I am a chilean citizen, I am owner of an Unimog 406, 1974 and I am searching information about the power of the truck (90CV or 140CV?, wich is right?)
I need too the explanation about the way that the Unmog use it power.
Eduardo Aguero
#42444
The regular power ist 84H4/DIN , it´s nearly the same than 90Hp/SAE. There are engines availible with different power. Wich engine-typ in in your truck. At the top of the engine, there is a plate where the typ is written. 353.902 has 84Hp, 353.940 has 110Hp and 353.907 has 125 Hp
#42773
Hello Eduardo.
I don´´t know this modell. I´m not shure, but I think this modell is build in Brazil. Ã
Ölwechsel Lenkgetriebe
Hallo Beim normalen Ölwechsel kann man den S[…]
Ist das Geräusch jetzt Geschwindigkeits oder […]
Suche in akzeptablen Zustand Beifahrersitzbank und[…]
Dank euch. Hilft mit schon weiter. :party
